Sponsor list
Warm Tips
Wasser Glass
Wired Designs
A & A Products
Aanraku Glass Studios
Art Glass Fusing Center
Artisan Dichroic
Best Mix Mold Mix
Bullseye Glass
CBS Dichroic
COE90.com
Centre DeVerre
Evenheat Kilns
Future Forms Molds and Stands
GlassStands.com
Hang Your Glass
His Glassworks
Lincoln Distributors
Nabertherm USA
Olympic Kilns
Orton Ceramic
Pacific Art Glass
Paragon Kilns
Skutt Kilns
Slumpy's
System 96
Two Lasses Glass Classes
UGotGlass?
Uroboros Glass
Warm Glass UK
POLISHING EQUIPMENT
In its simplest form, polishing glass is no more than manually rubbing an abrasive compound on the glass. Alternatively, a less time consuming, but still manual, approach involves the use of abrasive papers or hand pads to polish glass.
Abrasive and polishing surfaces are also available to fit many common mechanical devices. Pads and discs in various sizes and degrees of roughness are available for traditional stained glass grinders, Dremel-type tools, and variable speed drills. These pads are often diamond-coated, but can be made of cork or felt (usually synthetic cork and felt).
Moving up the scale in terms of sophistication (and expense), polishing glass can be done with belt sanders or more specialized tools such as reciprolaps. All of these approaches have in common that they require a steady stream of water and a polishing compound such as cerium oxide or pumice. The purpose of the water is to keep the glass from overheating and cracking, while the compound helps to abrade the glass and more quickly achieve a polished surface.
By using a series of finer and finer abrasive surfaces to wear away the surface of the glass, it is possible to achieve a high degree of polish. The artist generally starts with a coarser grit, abrades for a while, then switches to finer and finer grits until the surface of the glass is sufficiently polished. In essence, you just keep scratching the surface until the scratches get so small they can't be seen.
Click here for a more complete discussion of glass polishing techniques.
Return to top
Click here to e-mail comments
4140 Clemmons Road, #320
Clemmons, NC  27012   USA
