Sponsor list
Centre DeVerre
Evenheat Kilns
Future Forms Molds and Stands
GlassStands.com
Hang Your Glass
His Glassworks
Lincoln Distributors
Nabertherm USA
Olympic Kilns
Orton Ceramic
Pacific Art Glass
Paragon Kilns
Skutt Kilns
Slumpy's
System 96
Two Lasses Glass Classes
UGotGlass?
Uroboros Glass
Warm Glass UK
Warm Tips
Wasser Glass
Wired Designs
A & A Products
Aanraku Glass Studios
Art Glass Fusing Center
Artisan Dichroic
Best Mix Mold Mix
Bullseye Glass
CBS Dichroic
COE90.com
SAFETY EQUIPMENT
GLOVES
In warm glass work, there are two main situations that call for the use of gloves: protecting the hands from heat and protecting the hands from caustic chemicals.
Because the warm glass field sometimes involves the use of chemicals that may damage the skin, it's a good idea to keep on hand a supply of thin latex gloves and thicker plastic gloves. These are relatively inexpensive and should be used anytime you are dealing with potentially dangerous chemicals.
Several types of gloves are available for protecting the hands from the heat. The least expensive are welder's gloves, which are made of leather. Available at most hardware stores for less than ten dollars (US), they will protect the hands for temperatures up to about 500 degrees F.
Since leather has a tendency to hold heat (rather than dispel it), they will quickly become very hot if you hold on to an item for too long. Despite this shortcoming, they may be used for quick tasks such as grasping a hot handle to open the kiln or removing a mold that's been heated and is ready for kiln wash application.
You can get better protection from the heat by spending a bit more for a set of gloves that contain Kevlar. Originally developed by DuPont, Kevlar is a form of fiberglass. These gloves will not hold the heat the way that leather does, so they can be used for longer without getting too warm.
If you plan to work in higher temperatures, consider "Zetex" gloves. Zetex is a form of Kevlar that is especially formulated for higher temperatures. In general, gloves that are lined with wool or cotton are preferable to ones that are not.
RESPIRATORS
Good ventilation is essential in your work area, but situations sometimes arise where ventilation alone can't keep potential harmful fumes and contaminants away. In these situations it's a good idea to use a respirator.
There are two main factors to consider when selecting a respirator. First, it is essential that the respirator be the right size. One size does not fit all - an effective respirator should fit snugly around the face, so as to prevent fumes from slipping in.
Second, you should get the right kind of respirator for the particular contaminant you are trying to filter out. It may be possible to use a disposable paper mask for minor dust or fumes, but many vapors and chemical mists will require a more elaborate respirator that uses special cartridges to trap the offending materials. Different cartridges may be needed for different contaminants.
If you're not certain about which kind of cartridge to use or if your respirator will protect you, consult an informed expert about the best way to screen out the particular particles you're trying to safeguard yourself against.
Respirators aren't necessary for every potential problem, nor do they need to be worn continuously. It's even possible (though not exactly an act of genius) to get along without one or to substitute a paper mask in some instances. But if you intend to work frequently with chemicals or if you're particularly susceptible to dust and fumes, money spent on a good respirator is money well spent.
SAFETY GLASSES
It is essential that you own two different types of safety glasses. Clear glasses, generally with plastic lenses, are used for protection when grinding, polishing, or using other tools or machines that have the potential to throw off small particles that could damage the eye.
Dark glasses are useful for looking into the kiln at high temperatures. You need glasses that will protect your eyes from infrared rays. Welder's glasses (use #3 to #5) are inexpensive and work well. Didymium glasses made for lampworking are not sufficient.
For both kinds of glasses, make certain you select ones that fit well. Most kinds available will easily fit over a second pair of glasses if necessary. It's also possible to have special glasses made to a prescription if desired.
Click here to go to the final Supplies and Equipment topic, "Polishing Equipment."
Return to top
Click here to e-mail comments
4140 Clemmons Road, #320
Clemmons, NC  27012   USA
