2 questions, #1 about Spray A #2 problems with kiln shelf - WarmGlass.com
Linda Hassur
Postby Linda Hassur » Tue Jan 13, 2004 7:15 pm
#1 I was working with BE 0137 French Vanilla and used Spray A on it. It turned a ugly yellow color. I know that this particular glass causes problems with interactions to other glasses. I'm assuming that this is the reason I had the problem.
#2 I have a kiln shelf that has one area that won't accept kiln wash. I also have a slumper mold with the same problem. I've used sandpaper and some other methods of trying to "scuff" up the surface but these areas are "slick" and won't accept the kiln wash. I don't have a sand blaster but is there any other thing I can try? Thanks Linda
Postby Bob » Tue Jan 13, 2004 7:35 pm
Hi Linda,
The Lead in the overglaze reacts with something (sulphur?) in the French Vanilla to create the muddy colour .... at least that is what I believe the reaction to be. Someone please correct me if I'm wrong. Nonetheless it is a chemical reaction of some sort.
I think the only cure for the impermeable shelves/moulds is probably sandblasting. Go to a body shop, or find a place through the yellow pages that will rent you time on a sandblaster.
Hope this helps.
Cheers,
Barbara Muth
Postby Barbara Muth » Tue Jan 13, 2004 8:24 pm
ding ding ding. I think you nailed that one right on the head Bob.
Incidentally, French Vanilla is not the only glass with sulphur, there are other glasses with similar reactions to those of French Vanilla. Ah the joy of color reactions.....
Barbara
Barbara
LATEST GLASS
Users browsing this forum: No registered users and 33 guests
cron
