Failing Silicone: another option? - WarmGlass.com
aliceRI
Postby aliceRI » Sun Jan 12, 2014 9:41 pm
I am so frustrated. I have been using GE Silicone II for many years with only one issue about two years ago. That was from using an out-of-date tube of silicone that didn't cure. I use the silicone to adhere my glass panel to masonite or wood board. Since the summer, I have had nothing but problems. The silicone sometimes cures, sometime doesn't. I check the date, buy it at different locations, but still no consistency. I thought it might be the temperature of my studio so I have worked at keeping the pieces, after gluing, in a constant 65-70 degree environment. Still no consistency.
Does anyone use any other adhesive that is reliable for glass-to-wood applications?
HELP!
Greg Rawls
Re: Failing Silicone: another option?
Postby Greg Rawls » Mon Jan 13, 2014 8:19 am
I always buy a new tube of GE silicon II, open it and lay down a bead on a scrap. Let the bead cure for 6 hours. If it is not hard, I throw the silicon away.
Greg
Postby rosanna gusler » Mon Jan 13, 2014 5:20 pm
ah. good idea. thanks. e 6000 works well for me
Users browsing this forum: No registered users and 39 guests
cron
