Fire Polishing
Greg Rawls
Fire Polishing
Post by Greg Rawls »
I have finished a piece - 1/2" thick, 16" diameter. Bullseye glass. During cold working the piece I scratched it pretty bad so I need to fire polish. I want the piece shiny vs matte and I don't want to cold work it again! It is ready for slump. Suggestions? I'm thinking that I sandblast it then fire:
180 > 1000 > 20 min
300 > 1175 > 30 min
500 > 1275 > 5 min
9999 > 900 > 120 min
100 > 800 > 0 min
180 > room temp and off
What do you think??????
Greg
charlie
Re: Fire Polishing
Post by charlie »
i'm not sure 5 min at 1275 will firepolish. it won't in my kiln. i'd get a light matte surface.
you should look in at 1275, and see if it's shiny enough for you. if not, just increase the time.
Warren Weiss
Re: Fire Polishing
Post by Warren Weiss »
Greg,
I wouldn't exceed 150F/h in the initial ramp. Don't see a need for a hold at 1175. Like Charlie, not sure 1275 will do it from a sandblast finish. I'd go to 1300 for up to 10 min. Eyeball to decide. Hold at 900 for 2 1/2 hours and drop to 750 at 90 d/hr. Off at 750. Be sure to dam it as you did in the original firing.
Warren
Greg Rawls
Re: Fire Polishing
The hold at 1175 is to complete the slump. I'm trying to avoid damning because that means I have to cold work again. Thanks for the good advice!
Warren Weiss wrote:Greg,
Warren
Greg
Warren Weiss
Re: Fire Polishing
Greg,
The slump will complete before you reach 1300 without a hold at 1175. Didn't realize that you were firing in a slump mold so damming won't be necessary unless you exceed 1300.
Warren
