"Pebbles"....making yourself ?
Hello ! Is it possible to make "Pebbles" yourself ? If yes....different diameters ? Thank you for your help ! Jan
Re: "Pebbles"....making yourself ?
"Pebbles" are also called nuggets. Here is link to a previous post about making them...
http://www.warmglass.com/phpBB/viewtopi ... ts#p240202
Thank you Jenna ! I did not know they were called nuggets too Jan de Jong
Hello, the link is not working anymore ?? Not so clever, forgot to archive the schedule. JanJenna wrote:"Pebbles" are also called nuggets. Here is link to a previous post about making them...
You can make nuggets/pebbles from any glass you have on hand and in any size you wish... pretty much.
I think the choice of separator must be important since I've seen so much discussion about cleaning the bottoms.
'Back in the day' I just put a piece or a small stack of pieces on the shelf & fired to the look I wanted - maybe 1300°F? I used kiln wash I got from a potter friend.
Here's a link you might enjoy: http://fusedglass.org/learn/project_tut ... ss_puddles
Have fun - experiment!
Bullseye's fit ball project sheet gives some information that might be helpful with larger balls/nuggets/pebbles:
http://www.bullseyeglass.com/methods-id ... balls.html
