Smoke Detectors
Jerry
Smoke Detectors
In my kiln area I need to have a good smoke detector. The problem I'm having with the one I've already got is that everytime I open the kiln door to do what ever I need to do, the smoke detector goes off. I can move it to another room but run the chance of forgetting to bring it back. So I need one that won't scream everytime I open the kiln; I like to do raking and this dectector is a real pain.
Ideas please,
Jerry
Ideas please,
Jerry
Clifford Ross
Ron Coleman
Moving the smoke detector to the wall is a good idea and if that doesn't work look and see what type of detector you have. There are two types, ionization and photoelectric. The ionization detector is very sensitive. The photoelectric might be a better choice if you have the ionization type.
See the following link for more info.
http://www.usinspect.com/SmokeDetectors ... rTypes.asp
Ron
Ron
Jerry
Smoke Detectors
Okay, folks, down the wall it comes. It's already on the wall but pretty high up.
Appreciate the advice and I'll let you know what happens.
Jerry
Jerry
Jack Bowman
Jerry
Smoke Detectors
Jack,
You gave me quite a laugh. It is a wonderful idea and I'll take it under advisement. In the meantime, and I mean no offense by this, consider submitting this idea to Better Homes and Gardens; they'd probably pay you for it.
Thanks again,
Jerry
Thanks again,
Jerry
Jack Bowman
Jerry,
I've used that trick for over 20 years now. One other thing to consider. They make a detector for people with cooking skills such as mine. It has a button that disables the unit for a certain amount of time then resets. I saw this many years ago in a magazine. Somebody should invent one with different sensitivity settings such as "pot roast" "grilled cheese" "combing spectrum" "combing bullseye" and finally, a big hit here in the west this year, "brush fire".
Jack
Jack
Clifford Ross
Jack Bowman
Ron Coleman
Jack Bowman wrote:Jerry,
Jack
I was just checking out the kiln progress Jack. Looks like it's just about ready to fire.
Ron
Re: Smoke Detectors
note that they don't work if they are mounted too far down the wall. heat and smoke rises, and current code is that wired detectors have to be mounted to the ceiling at the highest point, not counting skylight tunnels.Jerry wrote:Okay, folks, down the wall it comes. It's already on the wall but pretty high up.
Jerry
Jack Bowman
Ron,
I test fired the kiln once and it has plenty of power. Still plenty of testing to do regarding temp variations throught the box.
I decided to move everything into our below grade one car garage which is all concrete except the door leading into the basement. I'll put a fire door there. I should have everything ready just in time to go to Whistler, BC to help set up a hot shop there. Probably won't get any serious use out of the new kiln till August. But then if Whistler works out well I might be able to squeeze in a trip to Michigan to visit family before the summer is over.
Jack
Jack
