Will a 70 grit diamond belt will "eat" glass significantly faster than a typical Glastar-type grinder?
I grind lots of small pieces to shape and I'm looking to speed things up.
Paul
Grinder vs. Diamond Belt
Paul Tarlow
Jackie Beckman
Paul Tarlow
Jackie Beckman
Brian and Jenny Blanthorn
Re: Grinder vs. Diamond Belt
We use a very rough diomond grinding wheel 30 / 40Paul Tarlow wrote:Will a 70 grit diamond belt will "eat" glass significantly faster than a typical Glastar-type grinder?
Paul
Then a 40 / 50 for finer
Electro plated
We use a bed 2 grind on n tip it twisal the glass arround
Or we also ajust the height
We then get a multy beviled edge we then finish this off by hand then
Tumble finish em then polish up the one or 2 surfaces
Thats how we do the pebbles
