All of a sudden I started to have needling problems when fusing BE glass at 1480 F. for 10 min.
I lowered the hold time to 7 min and then the joints between the pieces of glass on the top didn't completely run together. (There was a slight indent between the pieces of glass.) + there was still a little needling.
I measured the thickness of the fired piece, and guess what? It was only 0.235 inches thick instead of 0.25 +. What was going on?
I then measured the individual pieces from the original sheets and found out that the clear base layer was only 0.105 inches thick instead of 0.125 inches.
It turned out that the base layer was Uroboros machine rolled clear. I then measured all of the sheets of Uroboros machine rolled clear that I had and they ALL measured 0.105 inches or less thick.
I guess that what I am trying to say, is, If you start to have needling problems look at the thickness of the starting layers.
I am having to use a layer of BE thin on top of the Uroboros clear to eliminate this problem.
Somethingneweverydayboy (Jim)
