edge to edge fusing
edge to edge fusing
Just wondering when you do edge to edge fusing if you need a solid bottom piece or can you have 2 layers of the same size pieces on top of each other. If you can what can you do so they do not pull apart? Any help would be appreciated. Jabeb[/b]
Stuart Clayman
Glass wants to be 1/4" thick. If you butt 2 pieces of glass that are thinner than 1/4" they will tend to shrink when heated so that the edges get thicker. This will tend to unbutt the 2 pieces of glass resulting in a hole or 2.Jabeb wrote:so are you telling me you cannot but up two layers of cut glass and have them turn out?
I have been advised to grind the butt edges to a 45º bevel. This makes one piece overgang the other, giving you a better shot at them not separating.
Read up on the basic behaviour of glass when heated. Very little can be taken for granted. Tricky stuff glass.
