New molds
cindabr
New molds
Post by cindabr »
I bought some a couple molds. 2 plates and a bowl. The bottom is stamped with........... Do not heat over 250 degrees/per hour
This seems to me that it'll take forever to get where I want to slump.
Correct or incorrect??
Post by Marty »
Actually, that's pretty conservative for a slump, especially if you've got 2 or more thicknesses (1/4"+). I slump 3/8 to 5/8" and have learned (the hard way) to slow slump @ 100dph.
Slow man Marty
Lynne Chappell
Post by Lynne Chappell »
Some molds thermal shock rather easily. That's a pretty slow rise. I usually go 300 to 400 depending on the size. But I've cracked lots of molds too.
Joanne Owsley
Post by Joanne Owsley »
Isn't it possible that you'd only have to go that slow up to a certain temp. Then you could increase the ramp rate.
Just a thought.
~Joanne
dee
Re: New molds
Post by dee »
cindabr wrote:I bought some a couple molds. 2 plates and a bowl. The bottom is stamped with........... Do not heat over 250 degrees/per hour
the kiln goddess is determined to teach patience i think - when in doubt, go slow, i can get a slump into a ceramic mold at 1150 or 1200 deg depending on which kiln i use. i would rather go slow and get desired results than go fast and give the kiln goddess the opportunity to mess with my work ;P
D
Dee Janssen
Unicorn's Creations Studio
http://ucjewelry.com
dee@ucjewelry.com
