grinding discs
Linda Hassur
grinding discs
Post by Linda Hassur »
I have two studios with a Bevel Max machine in one and a Convertible Max machine at the other. They have different size center openings. I don't like the grinding discs that come with the machines. Instead of a disc with diamond grit over the entire surface, they have circles of grinding material on the disc. I need a source for new discs. Linda
Brian and Jenny Blanthorn
Re: grinding discs
Linda Hassur wrote:I have two studios with a Bevel Max machine in one and a Convertible Max machine at the other. They have different size center openings. I don't like the grinding discs that come with the machines. Instead of a disc with diamond grit over the entire surface, they have circles of grinding material on the disc. I need a source for new discs. Linda
Try
http://www.hisglassworks.com/index.html
