BORAX Qs,,,,,sprayer,,,recipe
does anyone have a suggestion for a spayer that wont get clogged with borax,,,,,,,,,also is there there a PERFECT mixture for the borax, is more better, is less better,,,,thanks,rodney
Re: BORAX Qs,,,,,sprayer,,,recipe
Here's the borax/klyr-fire/H20 recipe that I use:rodney wrote:does anyone have a suggestion for a spayer that wont get clogged with borax,,,,,,,,,also is there there a PERFECT mixture for the borax, is more better, is less better,,,,thanks,rodney
http://www.warmglass.com/basic/making_y ... htm#DEVIT2
Paul
The sprayer I have used most is a mouth atomizer. Someimes described as a cheap thrill. Get it at the art supply store for a couple of bucks.rodney wrote:does anyone have a suggestion for a spayer that wont get clogged with borax,,,,,,,,,also is there there a PERFECT mixture for the borax, is more better, is less better,,,,thanks,rodney
I have a cheap badger sprayer that works for things like borax, kiln wash, and mica, assuming you have compressed air available.
