CUTTING GLASS....
CUTTING GLASS....
HI,
I AM TRYING TO FIND A SMALL "MACHINE" THAT CAN CUT THICK, THIN AND FUSED GLASS IN A STRAIGHT OR CURVED LINE.
THANKS, ELIZABETH
THANKS, ELIZABETH
I bought this saw for difficult cuts in stained glass: http://www.delphiglass.com/index.cfm?pa ... o=itemList . I have found that it cuts through fused glass very well. It cuts curves very well, also. Straight lines are a bit more difficult, but I think that's operator failure on my part
I cut straight lines by hand so I don't get much practice with it.
Stacey
Taurus has a new saw coming out. I wouldn't buy a Taurus 2.2 until I looked at one of their new saws. I think you can add a heavier blade to the new saw which would be good for thicker fused glass and cabachons.
If you want a Taurus 2.2 I think you can find lower prices than $389.
I like the Taurus 2.2 but am looking forward to seeing what the new saw is like.
Dione
Dione
i requested literature on the taurus 3 - looks good and has 3 different blades, is supposed to cut thicker glass tho' i would imagine there's a limit to the thickness, my supplier is supposed to have them next month, check gemini's site and see if they have info on there yet, looks like it might be going on my xmas list for santa....Judy Schnabel wrote:As Dione mentioned, the new Taurus is coming out in mid-October. It's suppose to be to cut pattern bars.
Judy
D
Re: CUTTING GLASS....
A glass cutter is the best small tool ever devised for this.artlives wrote:HI,
THANKS, ELIZABETH
I recommend the CRL heavy glass cutting kit and a cutter for thinner glass along with it.
Bert, do you mean one of those small, pencil-like, non-electric gadgets with the little rolling wheel on the end? I suppose that could be very useful with all the power grid problems the world seems to be experiencing. I'm also becoming rather attached to my jewelry torches which are only dependent on the fuel tanks. My Little Torch oxy-acet has lasted over a year.
Yeah that's it. Mine runs on kerosene, K-1. I just taught inexperienced glass cutters to cut 3/8" float with these tools, curved and straitht lines.SAReed wrote:I got a very good price on my Taurus II. Had I known the Taurus 3 was coming out, I would have waited. But, I've had my T-II for about 4 months now and I'm very pleased with it. *still wish I had waited, though*
Check out the Diamond Laser 2000 and 5000.
No light - great water feed band saws.
I've cut 6" slab with it.
The blade takes less glass away than a T2.2 because it is thin. 1/6 vs. 1/8.
T2.2 will corner better because the blade is round not flat - easier circles.
2000 is THREE times the cost - about 1200.00
GRYPHON VS. TAURUS.........
HI ALL,
DOES ANYONE USE THE NEW GRYPHON DIAMOND SAW, OMNI 1?
WHAT DO YOU ALL THINK OF IT?
THANKS, ELIZABETH
THANKS, ELIZABETH
