1. When you do a fusing of stained glass scraps (same COE, of course), using a wire grid, do you use something to prevent devit? If so, what's the best way to do this? Can you just dunk all the pieces into Borax and water or Spray A? Or do you have a better way?
2. I opened the kiln the other day to find a small crack in a slumping mold. It's a shallow bowl/salad plate, and the crack extends from the edge to the center. Is it a lost cause, or can the bisque be repaired? If not, is it likely to split totally the next time used, or can it be used indefinitely? The widest part of the crack is about .5mm.
3. What can I do to prevent pieces from shifting in the heat??? I use white glue to get it into position until it's on the kiln shelf, but of course that burns off fairly quickly. I'm trying to make some dichro pendants that look great except that one edge where the top layer of clear shifted during the fuse
Okay, that's more than 3. Start charging me...
