Wahoo! The Felesatti wet grinder just arrived. I love new tools. I do have a quandry, though. I think I might be missing a part, or something....?
I have the metal "wheel clutch flange" part that threads onto the head of the grinder. I have a red plastic circular dealy (Do I call it a grinding disk base?) that has velcro on it, for attaching the disks. But I don't see any way to attach this part to the wheel clutch flange. Do I take the flange off and just screw on the grinding dealy?
Steph
OK, new Felesatti grinder questions
The treaded flange thingy holds the disk base on the spindle. Put the disk base on, thread the flange on, put the disk on the base (very straight), plug into a GFCI outlet (only), add lots of water and grind. It helps a bit if you have been lifting weights for a while. To hold the glass still you might need one of those rubber rug holders.
Good luck,
Good luck,
Tim
Flex grinder
I just got a sale flyer from Gran Quartz. They have a limited number of Flex LW 1503 wet grinders, reconditioned for $199, it has a built in GFCI and water feed hookup.
Alpha Ceramica polishing disks run from $24.8 (3") to 48.4 (5") for resin discs from 150 - 3000 grit.
Tim
This is hard to do verbally. I think I should try to be a little clearer. The metal flange, when I screw it on to the bolt, covers the entire bolt. So, I either have the wrong part & need something else, or I should unscrew the flange and then screw the plastic backing pad/velcro dealy back on. When I do that, there is about maybe 3/4" of bolt showing. Just doesn't seem right. Did I get the wrong stuff, or do I just go with molto exposo-bolto?
And geez, Bert, is my timing off or what?
Steph
Steph
Re: Tim
Steph,Steph Mader wrote:This is hard to do verbally. I think I should try to be a little clearer. The metal flange, when I screw it on to the bolt, covers the entire bolt. So, I either have the wrong part & need something else, or I should unscrew the flange and then screw the plastic backing pad/velcro dealy back on. When I do that, there is about maybe 3/4" of bolt showing. Just doesn't seem right. Did I get the wrong stuff, or do I just go with molto exposo-bolto?
Steph
If you didn't you should have ordered the rubber backer pad for the grinder. The backer pad that comes with the Felisetti is for granite grinding disks. Check this picture out on Granite City Website:
http://www.granitecitytool.com/showitem ... 0&catnum=0
You want the 4" pad. This has the velcro attachment to allow your disks to attach.
Phil
