fiber board
fiber board
Is the texture of fiberboard the same as a kiln shelf. I want to make a drop ring plate for an award and have never used fiberboard so I don't know what to expect as far as texture is concerned. Thanks Ann
Lisa Allen
Re: fiber board
The answer is no, there is much more texture on fiberboard. One fix is to kilnwash the board, smooth with your hand then burnout before using. This give a pretty smooth bottom where the lip is in contact with the board. Also, I don't know about ceramic drop rings, but on fiber drop outs, you can also get a stretching effect around the perimeter of the drop.Ann Demko wrote:Is the texture of fiberboard the same as a kiln shelf. I want to make a drop ring plate for an award and have never used fiberboard so I don't know what to expect as far as texture is concerned. Thanks Ann
Lisa
Lisa Allen
http://www.lisa-allen.com
