Cutting Fiber board for molds
I got a large piece of 1" fiberboard to use for mold making. I'm finding it very difficult to get a clean edge on this material Is ther a secret I dont know? I have already fired the pieces before i try to carve them is this proper or should I try it the other way? Any help will be appreciated :
Try carving before you burn them out. From my experience, they are less fragile and less prone to crumbling before they are fired. Also, use a really sharp exacto blade.
Lisa
Lisa
Lisa Allen
http://www.lisa-allen.com
I had the same problem. I am in the sewing business and we use a rotary knife alot. I used it on the fiber board and it worked outstanding. Here is a link:
http://shop.store.yahoo.com/cinemasuppl ... -6984.html
fiber board
I also received a hugh piece of board..never used it before. Would like to cut out a big ring (drop ring) to make a sink. Do I have to harden this and how do I go about it?
Re: fiber board
I simply cut it with a razor utility knife. It doesn't much matter what angle you cut to, square, beveled in or out. Prefire it and go. I generally use some dry powders on it to help seperate. I like alumina or plaster.doctac wrote:I also received a hugh piece of board..never used it before. Would like to cut out a big ring (drop ring) to make a sink. Do I have to harden this and how do I go about it?
fiber board
Bert, how long and how high to fire? Do I have to use hardener? before or after? Sorry for all the questions, just never used it before..Thanx
Re: fiber board
I have never used hardner so I can't comment on how it works.doctac wrote:Bert, how long and how high to fire? Do I have to use hardener? before or after? Sorry for all the questions, just never used it before..Thanx
I recommend prefiring the board up to the top process temp you plan to use it at.
