Will this work?
Will this work?
Hi warm glassers - relative newbie and first time poster here. This list and website has been a huge boon to my warm glass knowledge since previously I was a flameworker only.
I have some box bases (4.5" round opening) for which I want to fuse some 'tops'. Rather than just a flat round, I want to have an inner lip so the lid is more secure. In other words, I want a smaller circle indented under a larger one.
Initially I thought to use thick fiber paper (the stuff that is around 1/8" thick) but I had trouble getting a nice clean circle cut out. So I was thinking to go to the shop where I buy my greenware, get some clay, roll a sheet out 2 thicknesses of glass high and cut out the center circle like one might do in cookie dough, then fire to bisque and kiln wash.
Then I would put the my smaller circles (2 thicknesses) in the open hole and lay the larger circles over the top on a shelf. Kind of like laying a drop ring right on a shelf but filling the center of it, not 'dropping'.
My questions are
1) do I need to fuse the inner two and outer layers of circle separately into blanks and then put them together and tack fuse or full fuse? I want a good solid bond so I thought full fuse?
2) is there a better way to accomplish this than my plan?
Thanks!
My questions are
Thanks!
Barbara Muth
Bethany,
Glass and clay expand and contract differently. When you are done firing, the clay will have contracted more than the glass. That will set up some stress in the glass and you will have to break your clay form to get the glass out. No guarantees on whether or not the glass will break as well. You can address this problem by lining the inside of your ring with a strip of fiber paper, but I would probably cut the circle from the fiberpaper.
Barbara
addendum: I meant to say that the glass would have contracted more than the clay. I need to be lucid when I post!
Barbara
Ron Coleman
Thanks for clarifying - that could be very helpful down the road, the contraction rate information.
Ron, I am thinking on the same wavelength with you. The glass should not go over the outer edges of the clay, only on top and in the cut out. I think for fun I will try it both ways, fiber paper and clay. Should prove to be an education
Thanks agian!
Thanks agian!
Joanne Owsley
[quote="Bethany"]Thanks for clarifying - that could be very helpful down the road, the contraction rate information.
Thanks agian![/quote]
I'm with you. I think if the objective is to have the glass slump down into the hole in the center of the clay, leaving only a small lip on top, there really isn't any reason that this wouldn't work. We slump bowls into clay all the time with no problem. Perhaps I'm misunderstanding the overall objective. (Overall objective?!?! Can you tell I facilitated a 3 hour business meeting today? LOL)
Anyway, I say give it a try. Don't forget your kilnwash, and plan on maybe having to coldwork the outer edge, but it should work.
~ Joanne
"What neglected medication made you think THAT was a good idea??"
- me, to myself
- me, to myself
