using mica
using mica
I am making a sink and interested in experimenting with mica...unfortunately my airbrush needs repair. How else can I apply Pearl Ex? On top of glass? Between layers? Dry? or painted on? What is best?
Avery Anderson
You can paint it on - mix with Klyr Fire or acrylic water based medium. You can sponge it on, stipple it, etc. It won't sift. However, if you want a nice even coating, using an airbrush is the best way to go. If you want to encase the micas, fire first on top of the glass and then encase in a subsequent firing. Gold, russet, copper are best on clear or transparent glass, although not as dynamic as on the darker base. The interferance colors don't do well unless on black or dark glass.
Avery
Avery
You can also spread it on your kilnshelf dry and fire on top of it... but like Avery said, airbrushing gives you the most uniform coating. The biggest problem is that it is so light that it floats and gets all over everything if you try to sift it, or breathe on it with it spread out dry. Use a vacuum to clean it up.
There does have to be some glass to glass contact since mica works well as a separator. Also, you'll get trapped air bubbles when you encase it, unless you fuse the mica to the surface of one piece first, clean off the excess, then cap.
