Need battery operated lights for shows
				Barbara Silverberg
I'm wondering if there is such a thing as lights that are battery operated that can be used for both indoor and outdoor shows.  I make dichroic jewelry and light certainly helps show the effect.  At times I've taken pieces out of the tent into the sunlight.  I am hoping there might be an easier way.
				Cynthia
Check out these threads, they should be informative...Search the old archives too.  There might be some info there as well.
http://www.warmglass.com/phpBB/viewtopi ... y+lighting
				Nancy Juhasz
For portable electric here is what I did.  It is working for me.  I run lights, printer, and sometimes my laptop if I forget to charge the thing.  Deep marine battery, inverter but get a bigger one than you think you will need because things seem to work better.  I put both these things in a big plastic container hook up the inverter to the battery then the other things to the inverter.  Works well.  I am actually thinking of adding a couple of other things to drain the battery a little more like a hair dryer or heat gun.  Back in the archives there is a formula for how many hours of electric you can get depending on what you run.  I don't know it off hand.  Hope this is of some help.  I think my set up box and all was around $150.
							Nanc
				Barbara Silverberg
