Combing tool
Travar
Combing tool
Post by Travar »
I want to try combing glass in the kiln. What is the best material to make a combing rod or tool? What keeps the glass from sticking to the tool?
What isn't tried won't work. --Claude McDonald
Post by Brock »
300 series stainless steel. Get a 3/16" or 1/4" rod, about 30" long and grind the tip down to a dull point. Bend the last 2 or 3 inches from the tip down, at an angle, perhaps 45 degrees. Put a handle on it, and comb away. Immerse in water between combs. You'll be an expert on your second comb. Brock
Travar
Post by Travar »
Thanks, Brock. I'm on my way.
Judy Schnabel
Post by Judy Schnabel »
If you have Brad's book, turn to pages 80 and 81 for pictures on combing.
I've found out it's not quite as simple as it looks and sounds.
Practice. Practice. Practice.
Judy
