For those that wanna get some more knowledge on the subject
The growth of ice is very similar in many respects
In the article note
No neucleation points = no ice
This is also true of other materials which can exist in a cristaline / liquid form
In glass when using anti devit stuff the newcleation points R disolved and or the surrounding glass is 2 liquid 2 grow cristals
I n my buddies have a lot of stuff in the archives on devit
Thanks Ron 4 the original link
http://www.its.caltech.edu/~atomic/snow ... roject.htm
Brian
Devit
Brian and Jenny Blanthorn
Hugo Gavarini
Thanks Brian and Ron. Interesting article. I always am wondering what physical-chemical reactions produces anti-devit stuff. I think anti-devit can't drop liquidus temperature enough to prevent crystallization from occur. I might vote for a nucleus dissolution mechanism, however I would like to know for sure.
Hugo
Hugo Gavarini wrote:Thanks Brian and Ron. Interesting article. I always am wondering what physical-chemical reactions produces anti-devit stuff. I think anti-devit can't drop liquidus temperature enough to prevent crystallization from occur. I might vote for a nucleus dissolution mechanism, however I would like to know for sure.
Hi Hugo
If the glass is 2 liquid the devit cant grow
Normal glass with devit in it heated so realy runney, then devit will disolve
The anti devit stuff does this but at a lower temp
Brian
Paul Tarlow
borax on enamels
So I have new work that uses enamels (Thompson) on float. I've got very light devit in the non-enamel spots.
If I spray some borax will it have any negative effects on the enamel?
Paul
Paul
Lynn Bishop
Re: borax on enamels
I am not shurePaul Tarlow wrote:So I have new work that uses enamels (Thompson) on float. I've got very light devit in the non-enamel spots.
Paul
There was some chat about borax being water soluabble over time
If the enamel has 'devit' on it n the enamel is liquid / shiny
My guess is its not devit
A molten enamel should not B able 2 devit as it is 2 liquid
MayB fire higher ??
Brian
