Disappearing act~~~~~~~~~~
Hi all,
I just received my new Tauras 3 ring saw, and want to know of a good marking pen that will not wash away my pattern, with all the water that is being sprayed on the glass.
Vickie
Vickie
I've used the Deco (?) pen with good success. I get them through The Art Glass House. You can get white or black. One time I couldn't find my Deco so I used my Pilot pen. Same thing happened with me. The mark washed away before I could get the blade to it.
I tried Vaseline on the mark but hated cleaning off all that grease, so I ordered more pens.
Judy
Judy
Whatever kind of pen you use, if you allow it to dry awhile (probably a days is best, but at any rate give it some time), it won't come off as readily. I haven't found anything really perfect -- the combination of vibration and water is very effective at lifting marks or rubber cement. The most sure method I found was to use a Pebeo marker, Vitrail or ...whatever the other line is
, and bake it on. Because the mark is thin, it doesn't have to dry long, and doesn't have to bake long. I haven't had much luck with the vaseline/chapstick method: I have a hard enough time seeing the mark through the water; with goo on top of it, I can only guess where the line really is.
You only need the thinnest of coatings with vaseline...it doesn't need to be thick or gooey. Just touch your fingertip to the vaseline and wipe it over the mark. That way you can see through it and the residue comes off when you wipe the water off after you're done cutting/grinding. The Markstay stuff works, too, but considering the price differential and easy availability, I much prefer the Vaseline (even cheaper if you don;t insist on name-brand!!)
