Putty:for the leaded glass crossover crowd?
Joseph Tracy
Does anyone know something about dap 1012 as a putty for leaded glass.
Better yet does anyone know of an article comparing different waterproofing cements/putties? I know this is sorta OT but this is the most knowlegeable crowd I know for such topics.
It's got a pretty scary MSDS. And, it's aluminum coloured. Brock
http://www.dap.com/retail/retail_detail ... odhdrid=68
there's a stained glass mailing list that i know of. you can get on it with an email to glass-request@bungi.com
dap 1012 is basically calcium carbonate (whiting) with some oils and a form of powdered aluminium. you can make your own pretty easily and cheaply with whiting, carbon black (or black paint or concrete tints), and boiled linseed oil. the advantage to this is that you only need to mix what you need. keep the powdered ingrediants in a can and it won't dry out like a can of dap will.
Becky Bergsma
I have used the DAP for many years, when I get a new can I take it all out and mix it up like bread dough to mix the oil that tends to come up to the top, then I put all back in the can and after I use it I put water over the top, that keeps it from getting dried out. I brush it on with a plastic bristle brush, the sprinkle with whiting and brush that good with a different plastic brush, let it set overnight and clean the excess putty with a sharpened chopstick then brush to polish with a tampico brush, clean corners with a sharpened chopstick with a rag over it.
I used to mix my own using plaster of paris,portland cement, linseed oil and turpentine, now that was some nasty stuff
Becky
Becky
Dennis Brady
The best possible putty for leaded glass is whiting (calcium carbonate) mixed with 50/50 natural and boiled linseed oil. Mix to the consistency of thick peanut butter.
NEVER......repeat NEVER...use ANY material that contains either cement or plaster. Both these ingredients absorb water and will produce mildew.
DeBrady Glass Ltd http://www.debrady.com
Victorian Art Glass http://www.vicartglass.com
Glass Campus online classes http://www.glasscampus.com
Not sure if this is directed at me, but I want to clarify that PacMix Color is NOT concrete. It's a fine powder that's used to color concrete.Dennis Brady wrote: NEVER......repeat NEVER...use ANY material that contains either cement or plaster. Both these ingredients absorb water and will produce mildew.
Stacey
Dennis Brady
Not directed at any PERSON specifically, but at PRODUCTS specifically. There are several different compounds marketed to be used to putty leaded windows that DO contain these ingredients. They should NOT be used. It's wise to read the ingredient labels. It's wisest to make your own putty and have a product that you KNOW will work well. Just don't use your wife's cuisinart to mix it. Trust me on that.
You can use any of many different materials to colour putty (as long as they don't contain plaster or cement). Lamp black (available at most art supply shops) or concrete/mortar dye (available at ceramic tile suppliers) are the most common. There are also several excellent industrial dyes that work exceptionally well, but usually aren't available in other than industrial quanitities.
Joseph Tracy
