bumpons
bumpons
anyone have a good supplier of these in 1000ct amts?
Re: bumpons
I usually buy mine from McMaster-Carr. They have a decent assortment and sell them by the sheet which varies depending on the size.
Re: bumpons
Jim, what do you mean by 1000ct? HIS has some on sale right now but not sure if that's what you're looking for.
http://www.hisglassworks.com/cart/Rubbe ... LKHM45QPa4
Re: bumpons
I use bumperspeciaities.com. They have anything you may need and good prices.
http://www.bumperspecialties.com/home-en.php
Re: bumpons
I like these guys:
http://www.abcplastics.com/index.php?pa ... &Itemid=53
Re: bumpons
If you are looking for the actual 3M bumpons I get those from Uline.com They are more expensive than many of the knockoff bumpons, I've found some of the cheaper ones to be, just that CHEAP. In that they turn yellow and the adhesive fails.
http://www.uline.com/BL_6132/3M-Bumpons
Rick Wilton
Re: bumpons
To make them 'almost' dishwasher proof apply weight/pressure for 24-48 hours.
Re: bumpons
Thanks for the input
Re: bumpons
Rick, do you know where you can buy just a couple sheets of these? Most of the places I've seen sell them by the case...Rick Wilton wrote:If you are looking for the actual 3M bumpons I get those from Uline.com They are more expensive than many of the knockoff bumpons, I've found some of the cheaper ones to be, just that CHEAP. In that they turn yellow and the adhesive fails.
Re: bumpons
If I need a sheet or two I go here: http://www.nbhco.com/
They're local in SE Portland.
Re: bumpons
I buy the 5302 by the case of 3000. If those are what you are looking for send a pm and I'll send you a sheet or two.
Rick Wilton
Re: bumpons
I've got many, 3-M brand. cost $.06ea. let me know if you need some.
