I just purchased a Caldera to have a travel kiln. Realizing it probably takes a few experimental runs, will there be much difference in firing from a Fusion 16 with a top/lid element, vs the side elements in this small kiln? I plan to fuse 6x6 tiles.
chelseaglass
Element placement and firing results
Arnold Howard
Re: Element placement and firing results
Thank you for your business. If you fire with full rates, you will notice that the Caldera fires much faster than the Fusion-16.Chelseaglass wrote:I just purchased a Caldera to have a travel kiln. Realizing it probably takes a few experimental runs, will there be much difference in firing from a Fusion 16 with a top/lid element, vs the side elements in this small kiln? I plan to fuse 6x6 tiles.
chelseaglass
Sincerely,
Arnold Howard
ahoward@paragonweb.com / http://www.paragonweb.com
