T-Fal Forms
T-Fal Forms
I just found a T-Fal coated cooking utensil that would make a great slumping mold if safe. I read a generalized MSDS on T-Fal which did not address what happens in temperatures greater than 350F. While sandblasting the item is probably what I'll do to remove the coating, I do wonder about the consequence of firing T-Fal in a kiln. Anyone have any info?
Jerry
Re: T-Fal Forms
You can try it in your kiln and let us know....
Re: T-Fal Forms
The teflon will burn off in the kiln and the byproducts of decomposition are probably pretty nasty.
I would be very hesitant to put T-fal in a kiln for fear of contamination or element damage and I sure as hell wouldn't do it unless the kiln was outdoors or extremely well ventilated tot he outside world.
I think I'd sandblast all the teflon off if I really wanted to use it.
Steve
Re: T-Fal Forms
yep toxic as hell to burn off. r.
Re: T-Fal Forms
http://www.t-falusa.com/Consumer+servic ... 59FBCB4%7D
I didn't bother to find out what the metal is.
Don't.
Don't.
Re: T-Fal Forms
Heh. It's aluminum.Marty wrote:http://www.t-falusa.com/Consumer+servic ... 59FBCB4%7D
Don't.
Steve
