I did buy one but its terrible or I am terrible with it, or both
Any help would be appreciated!
Thanks, Joe
I think BE had a tech sheet on cutting glass that would probably be helpful if someone can help us find it as I can't find diddly on their site.ironman55 wrote:Thanks to all who posted. I have only cut bullseye glass so far. Some pieces score great and others come out like I used a jackhammer. The texture on each piece is a little different. Now I have a decision to make. I have been a cabinetmaker for over 30 years so I think in terms of a bandsaw when it comes to curved pieces. I do however need to learn to cut with a cutter as well. Nothing beats hands on
Thanks, Joe
I use this custom grip cutter, too. I bought a pistol grip last year and haven't cut one piece of glass with it. I was thinking it might be easier on my arthritic hands, but for right now, I love the control so I guess I'll wait until I'm REALLY in pain to switchBert Weiss wrote:I've been cutting glass since 1972. There is one cutter that stands out far and above every other cutter I have worked with. My cutter of choice is the Toyo Custom Grip tap wheel cutter. I use it for everything from 3mm Bullseye to 19mm float. I do not recommend it for glass thinner than 3mm. It can last for longer than a decade, used every day. .
Here's the 'Studio Tips' document from BE for cutting glass; they added a document index at some point so I was able to find it http://www.bullseyeglass.com/methods-id ... tting.html.ironman55 wrote:Thanks to all who posted. I have only cut bullseye glass so far. Some pieces score great and others come out like I used a jackhammer. The texture on each piece is a little different. Now I have a decision to make. I have been a cabinetmaker for over 30 years so I think in terms of a bandsaw when it comes to curved pieces. I do however need to learn to cut with a cutter as well. Nothing beats hands on
Thanks, Joe
Don, those are not easy cuts. You can't argue with success. The tap wheel has little bumps on the wheel bearing hole. These serve to drive the cutting wheel a little deeper in to the glass. It is designed to minimize flare when breaking out the cuts. The thicker the glass, the bigger a deal the flare becomes.DonMcClennen wrote:In the last 2 days I have cut over 400 strips 1/4" wide x 24" long with 100% straight accurate breaks.... Pistol grip, tap wheel, does the trick.. I think the tap wheel really helps.
I work primarily with float glass. The ideal way to work is to buy a 2 ton case, and everything in the case is compatible. I am able to pay attention, and only cut on the air side of the glass, so I can tell without testing, which side is which.ironman55 wrote:Thanks to all for the input. Where do you find a cheap source of float glass? Do you use salvage glass? Can float glass be used to slump?
Thanks, Joe
