The longest zero centering ruler I can find that's appropriate for use with the Morton Mini Surface is 24". The one I'm using now has the zero 6" from one end, and 18" from the other. It reads both English and metric.
I would like to find:
1. Metal rule
2. Both measurement systems
3. Zero at 12" from end, 24" from the other.
4. Pre-drilled at the 12" end, preferably, to accommodate a threaded dealy that will affix that end to the cutting grid.
Does such an animal (or one close to that - longer would also work) exist? Source?
Thanks.
Source for 36" or Longer Zero Centering Ruler?
Dave Jenkins
Glass at Harbor Gates
Cypress, TX
Cypress, TX
Re: Source for 36" or Longer Zero Centering Ruler?
Try, online, some of the woodworking supply companies. Some of them carry this sort of thing. I don't remember seeing one that meets your requirements but I wasn't looking either.
Jim
Jim
Tim Yardic
Yardic Glassworks
Yardic Glassworks
Maybe a bit fancier than you want:
WWR36 and WWR900
http://www.woodpeck.com/woodworkingrules.html
Available in imperial or metric, but not on the same rule. They have combination rules, but not a centering rule.
WWR36 and WWR900
home depot has 4' long tsquares for drywallers cheap. you might get one of those, cut off the top of the T, predrill, and etch the lines you need.
Thanks, all. I went to the woodpeck.com web site, and I think they have exactly what I want. Looks like good quality stuff, too.
Dave Jenkins
Cypress, TX
Cypress, TX
Here's another choice:
http://woodworker.com/12x4l-to-r-read-t ... archmode=2
http://woodworker.com/24-centering-rule ... archmode=2
Jim
Jim
