Hello,
My name is Lawrence Morrell (www.LawrenceMorrell.com) and I am considering a custom order for either the Tekta 1100 (green) or 1101 (crystal clear) in 12 mm or other thickness (custom size). Is anyone interested in going in together on this? Two people would be about $1,515 ea for 7-8 sheets, 3 people would be $1,012. for 5 sheets.
we can change the length they are cut off but have to have all the same width, see below.
From Sarah Givens at Bullseye:
Here’s the breakdown of costs on a special order of the 12mm Tekta (1100), in sheets approximately 24” x 40”.
Estimated* weight per sheet – 44 lbs per sheet
44lbs x $4.00/lb = $176
$176 x 15 sheets (minimum order) = $2640
$2640 + 15% special order fee = $3036 estimated total cost of the special order
* We recommend having a 2” buffer on all edges, at least, for ease of trimming down.
We can get a pretty uniform 24” width, but the length of each sheet will vary, affecting the weight/cost of each sheet.
Expect 8 weeks lead time, but once ordered & scheduled for production, I can get a better estimate on timeline.
							Bullseye 12mm Tekta Custom order buy together?
				Lawrence Morrell
"Do the thing, and you will have the Power" Emerson
"Things are not difficult to make, what is difficult is putting ourselves in a state of mind to make them" Brancusi
"Art is a lie that tells the truth" Picasso
