DTC 800
jim simmons
DTC 800
Post by jim simmons »
Who makes the dtc 800 programmer?
Mine just bit the dust and I don't feel like paying $366 from Paragon
Thanks in adv.
Jim
Arnold Howard
Re: DTC 800
Post by Arnold Howard »
Bartlett Instruments made the DTC 800. They can usually refurbish the circuit board for a nominal fee.
Sincerely,
Arnold Howard
Re: DTC 800
They also make the RTC 1000. You might want to look at that one. Typically, Bartlett supplies the board attached to the front of the controller. You need to add a separate power supply. They will give you the spec. http://www.bartinst.com
Don Burt
Re: DTC 800
Post by Don Burt »
Arnold Howard wrote:Bartlett Instruments made the DTC 800. They can usually refurbish the circuit board for a nominal fee.
Sincerely,
Arnold Howard
ahoward@paragonweb.com / http://www.paragonweb.com
Cool response.
jim simmons
Re: DTC 800
Why would I want to consider changing?
Does the rtc 1000 offer any advantages?
Jim
Bert Weiss wrote:They also make the RTC 1000. You might want to look at that one. Typically, Bartlett supplies the board attached to the front of the controller. You need to add a separate power supply. They will give you the spec. http://www.bartinst.com
Re: DTC 800
jim simmons wrote:Why would I want to consider changing?
Jim
Jim. I am not familiar with the 800 model. The RTC 1000 is the latest model of the 12 key controller. It does up to 3 zones, and has the capability to run a high temp limit control system. It is the least expensive, most powerful controller I know of. You can use it with mechanical, mercury, or SSR relays. It also has a computer interface you can add on that allows you to program on a computer and monitor and control it remotely. The cool thing is that they sell it to you not as a plug and play, but as a stand alone circuit board behind the 12 key front. You cut the hole in the box, add the power supply and relays and you are in business.
jim simmons
Re: DTC 800
Thanks, Arnold. That speaks volumes about your integrity.
Sincerely,
Arnold Howard
tob
Re: DTC 800
Post by tob »
Jim
If your DTC 800 can't be repaired for a reasonable price, the RTC-1000 offers the advantage of being currently in production, which the DTC 800 is not. There are probably some other advantages too, but I would consider that to be the big one. ;)
The RTC-1000 info page is here - http://www.bartinst.com/kilns/2
