So... I can't just glue the glass to the aluminum/copper base, because it seems to me the glass to copper would be a failure point (actually, it would be gluing the glass to clear pieces of glass to the base, since I need a standoff -- if I were just going directly to the copper without standoff, I think there would be enough surface area to keep it secure), Do you think this is a suitable use of Hang Your Glass stand-offs? Not the edge stand-off, but the kind that you glue the glass to. I haven't worked with those stand-offs so I don't know if the copper/aluminum would be thick enough for the stand-offs to hold securely.
Is there a better option? I have limited experience/skills with metal, which is why I am going the route I am. I have only found patinaed copper in light-weight gages. I know I can cut the aluminum, and I can apply the patina sheet with silicone or some other adhesive. The pieces for the bison won't be THAT heavy. I think they've asked for about a 2x3 foot piece, so the bison will be sized proportionally, and in pieces. Maybe I can just glue the glass bison pieces to glass stand-off pieces to copper to aluminum... That's a lot of glue
Comments?
