Coldworking/grinding leaded crystal?... - WarmGlass.com
Mia M
Postby Mia M » Sun Jan 08, 2017 1:16 am
Unfortunately, grinding the mold lines for my leaded crystal sculptures is a necessity, so it can't be avoided. My only choice seems to be to grind in a booth with an exhaust fan, wear a mask, and be as careful as possible. Any thoughts about leaded crystal coldworking and safety?...
jolly
Re: Coldworking/grinding leaded crystal?...
Postby jolly » Thu Jan 12, 2017 9:35 am
I don't consider any glass dust to be safe for exposure to my lungs so I certainly wouldn't consider leaded glass to be safe. If it were me, I would use the same precautions as for any grinding of glass and then I would buy a lead testing kit -the EPA has some recommendation on which kits are best- and test the slurry to see if the lead is now a problem for disposal.
Greg Rawls
Postby Greg Rawls » Fri Jan 13, 2017 8:19 am
There are a lot of variables here - how much available lead in the crystal, how much and how long you are grinding, how you are grinding, etc. My recommendation is to grind wet and wear a P100 respirator. Try to contain the dust and carefully clean your equipment when finished.
Greg, retired Certified Industrial Hygienist
Greg
Mia M
Postby Mia M » Sun Feb 19, 2017 7:15 pm
Thank you, Jolly and Greg. I appreciate your comments and will try to follow your suggestions.
Return to “Newcomer Forum”
Users browsing this forum: No registered users and 4 guests
