Spectrum System 96
susanmozingo
Spectrum System 96
How can you tell which side is the top side of a clear sheet of System 96?
Re: Spectrum System 96
If you have any seeds in it they are on the bottom. also, the back side usually has a slight matte look.susanmozingo wrote:How can you tell which side is the top side of a clear sheet of System 96?
I don't think there is really a "top" side. There is a smooth side and a side that is a bit textured. Depending upon what you are doing dictates which side is facing up.
For instance, when layering glass pieces, I will try to put texture facing texture, or at least texture facing smooth to minimize bubbles (smooth to smooth is when you'll more likely get bubbles).
Best, Dana
Best, Dana
jim simmons
The side that has the label is the "top" side.
The other Jim
The other Jim
Jim is right, but keep in mind that art glass isn't like float glass which has one side "contaminated" by the float process.
jim simmons
Tony.
By "contamination" I assume that you mean the tin left by the float process.
The other Jim
The other Jim
Yup. That's what I meant, and why most people ask which side is up.jim simmons wrote:Tony.
The other Jim
