zyp coating
zyp coating
Formally known as mr97.
Has anyone used it instead of kiln wash on a shelf for fusing?
The other Jim
The other Jim
Re: zyp coating
Why would you want to?
Re: zyp coating
Hi Brad.
Because I have developed a bad shoulder that prevents me from lifting anything heavy.
My mullite shelves are just to heavy to lift to scrape and lift out of the kiln.
The other Jim
The other Jim
Re: zyp coating
Sorry about your shoulder. Having just turned 65, I can certainly sympathize.
I haven't tried ZYP on the shelf, but am not sure how it would hold up to repeated firings. I guess I would just use thinfire or Papyrus, easy enough and you can vacuum it out as needed. But you can always try the ZYP and see how it holds up. One thing I don't like is that it's irreversible without sandblasting it off.
Re: zyp coating
Hi Brad
The other reason is that I am wanting to try a couple of techniques that thin fire won't work with.
These are some stack firings that consist of stacking 13 layers of glass and then have them spread out.
I am afraid that thinfire would get embedded in the bottom layer.
And because I don't have a sandblaster, it would become a part of the "design". :>)
66? you are just a young pup. My shoulder started to bother me when I was around70 and has just gotten worse.
*85 and counting :>)
The other Jim
The other Jim
Re: zyp coating
Great, something to look forward to.jim simmons wrote: My shoulder started to bother me when I was around70 and has just gotten worse.
Re: zyp coating
my experience with all the coatings was mixed. The lower temperatures worked better. Full fuse and higher not so good. Kiln wash the best. I started just stripping and recoating in the kiln.
Re: zyp coating
Zyp still has to be removed. It can be brushed away with a paintbrush and then resprayed. However, it's nasty stuff to breathe and so I would not want to spray or brush in an enclosed area. I always work outside, and often even put on my respirator (or hold my breath - ha ha
From the SDS:
HAZARD STATEMENTS
Flammable Category 1 H222 Extremely flammable aerosol.
Gas under
pressure
H280 Contains gas under pressure; may explode if
heated.
Eye Irritation Category 2B H320 Causes eye irritation.
Inhalation Category 4 H332 Harmful if inhaled.
STOT:SE Category 3 H335 May cause respiratory irritation.
STOT:SE Category 3 H336 May cause drowsiness or dizziness
P261 Avoid breathing dust / fume / gas / mist / vapors / spray.
P264 Wash hands thoroughly after handling
P271 Use only outdoors or in well-ventilated area.
From the SDS:
HAZARD STATEMENTS
Gas under
pressure
heated.
Re: zyp coating
First of all, Dana. Let me congratulate you on all of the hard work you and Tanya have done for people in the warm glass field.
You both have done a lot to further the education and the fun of the warm glass community.
Next, Thanks for posting the MSDS for zyp coatings. I think that a lot of people are now aware of the dangers and will take appropriate precautions.
I am well aware of the dangers myself. I have been using it for a long time now, and use a hepa vacuum and OSHA approved mask for chemicals.
The other Jim
The other Jim
Re: zyp coating
using kiln wash seems the most sense to me.
I was even given a bottle of liquid equivalent of a zyp type and chose not to use it.
Buy a drywall sanding attachment for collecting the dust while sanding the shelves inside your kiln.
Hardware stores have lots of them to choose from.
Re: zyp coating
Hi Kevin
drywall sanding attachment ?
Could you please explain ?
I really can not do any even moderately heavy lifting anymore
Kevin Midgley wrote:using kiln wash seems the most sense to me.
Re: zyp coating
there are lots to choose from out there some for a lot of money.
Using the carbide open mesh variety sand paper stuck on the bottom of one of these units will allow dust free sanding. Well dust free if the vacuum you are using is of high enough quality and doesn't just blow the dust out the exhaust port of the vacuum. Some have extension handles meaning you would not have to bend over inside your kiln.
I've not tried this unit but it does make complete sense and the reviews are not totally bad.
https://www.homedepot.com/p/Saint-Gobai ... 117986-_-N
Re: zyp coating
Different Danajim simmons wrote:First of all, Dana. Let me congratulate you on all of the hard work you and Tanya have done for people in the warm glass field.
From hot, sunny & dry Utah,
Re: zyp coating
I tried brushable ZYP boron nitride on fiber molds. It releases one time, firing up to fuse temperature the next time results in the coating sticking to the glass as a hazy film. Zyp has to be removed and replenished with a fresh coat which is pretty impossible on fiber.
