How do you tell if all kiln wash is removed?
Kinsey K
Post by Kinsey K »
I acquired some casting molds from someone who over-applied kiln wash. I want to remove it and use boron nitride.
How to tell if it is completely clean? If there is a small trace left, will it prevent the BN from working properly?
I think I have it mostly taken care of (scraper, chopstick, scrubbie, sandpaper, brush). Having trouble around the hole of the holey moley, though. I am itching to go to my dremel and use a light abrasive to go over the surface. I think it would be easier to see if I'm hitting everything evenly and smoothly.
Thoughts, advice?
Kinsey
Kinsey K
Re: How do you tell if all kiln wash is removed?
Post by Kinsey K »
Update:
Ok, I couldn't stay away from the dremel. I found a small, stiff-bristled brush attachment (not wire). Perfect size for getting around the holey moley hole. I went lightly over the rest, too. I'm thinking a bit of kiln wash remained on the surface because it kicked up dust. (When I tried the brush on the mold's un-washed underside, no dust.)
Also, after a couple passes with the brush, it looked more like the bare bisque color than it did before. Not entirely even, though, so my original question remains.
k
Post by Kevin Midgley »
wash off the rest of the kiln wash and use a tooth brush.
I'd never use Boron. Then you are stuck using it.
Just use Bullseye kiln wash.
jim simmons
Post by jim simmons »
I use Bn for all of my molds but use BE kilnwash for my shelves.
Works for me.
The other Jim
