breakthrough rigidizer news
I just spoke to Wes Jones at Wesbond corp.  They are a maker of rigidizers that major companies buy from.  They make both colloidal silica and alumina.
He told me that colloidal alumina seems like a much better material to be rigidizing boards with, for several reasons. The silica turns to crystabolite when heated and crystabolite is the dangerous stuff. Alumina is the basic ingredient in seperator so using alumina instead of silica results in a surface that does not have to be kiln washed. Eventually you do need to recoat with the alumina. Colloidal alumina is a win/win relative to using colloidal silica.
They sell Wesolock D as a powdered colloidal alumina. Right now they charge $2 per pound and the smallest package is a 20 lb. carton. You mix it with water as a 30% solution so 20 lb makes roughly 6 gallons of rigidizer. The material is not sensitive to freezing like colloidal silica is.
[/url]http://www.wesbond.com/wesolok_db.htm
I love it when I find the source manu ... work fine.
I believe that it will work on fiber as well as board.  He explained to me that the alumina travels in to the interior of a board whereas the silica tends to remain on the surface.  This could result in a denser and more stable mold than one made by rigidizing with silica.
				Cynthia
Thanks for the tip Bert.  Do you know if you could you use it on a fiber shelf that is already rigidized with silica?  I have a magnaform shelf that is a Unifrax product and it came already rigidized.  I am assuming it was treated with silica.  It sticks like nobody's business (even with good new coats of kiln wash). I would like to keep the fiber shelf, but eliminate the need for paper...
Otherwise I'm going back to mullite shelves.
CynthiaCynthia wrote:Thanks for the tip Bert. Do you know if you could you use it on a fiber shelf that is already rigidized with silica? I have a magnaform shelf that is a Unifrax product and it came already rigidized. I am assuming it was treated with silica. It sticks like nobody's business (even with good new coats of kiln wash). I would like to keep the fiber shelf, but eliminate the need for paper...
Follow the link and give Wesbond a call. I'm sure that they would have a clue about how they interact, as they make both products.
				Brian and Jenny Blanthorn
Re: breakthrough rigidizer news
Yo BertBert Weiss wrote:I just spoke to Wes Jones at Wesbond corp. They are a maker of rigidizers that major companies buy from. They make both colloidal silica and alumina.
Sounds good
But I thought a colliod was some stuff u only got as as solution
As far as I know u cant get collidal silica as a powder
There was some about using colloidal alumina as part of a glass furnace construction over craftweb
Does colloidal alumina separate out after mixing ??
Anyway if it works sounds realy good
Brian
Brian
.[/url][/quote]
Yo Bert
Sounds good
Brian[/quote]
Here is some stuff from my top secret private archives
AUTHOR: Jim Murphy
DATE: Saturday, 21 December 2002 at 11:37
Reply To: (#78311) Re: 'Q' colloidal silica...'Q'
Author: OT Brian + Jenn
Date: Saturday, 21 December 2002 at 05:27
Colloidal Silica is an aqueous dispersion of discrete particles of amorphous
silica. The silica particles have a negative surface charge which causes the
particles to repel one another, resulting in a stable silica solution. (Source
= Ceramic Industry 2002 Materials Handbook)
So, the real key is the use of amorphous silica.
Jim Murphy
XXXXXXXXXXXXXXXXXXXXXXXXXX
I thought I had more stuff on colloids but I cant find it
But I got this on Cheetin technology
If using this new stuff U may get away without the bat wash
XXXXXXXXXXXXXX
: Do you mean that I should use rigidizer on the fiber
: board? If so, do I prefire the binder out, then use
: rigidizer on the fiber board, then kiln wash it...AND
: The glass wont stick to the board and tear it up...AND
: it won't warp?
: If so, You are my knight in shining armour. If not, I
: still like you.
Dear Damsel In Distress
Ok I will explain the complex technolgy behind
Fiber, Dizer n Wash
The labs have been working on this day and night 4 many years combining much of the research from all the recent and old technology which they have developed or stolen
Some of the new discoveries were only a few days ago and have not yet been fully assessed 4 there cheetin rating
However As UR need is great here U go
This is what they came up with
This was using 10mm fibre board but I guess would work ok on thinfire and her buddies
Method unfired board
Colour rigidiser with food colour
Something that matches UR decor
Paint rigidizer on board
Allow 2 dry a little
Take care as it is very soggy n fragile
Paint with bat wash
U can do a few at once
Now put these on flat kiln shelf all together
Flat
No spacers Oh no no no
If they R warped put a shelf on top + weight
Leave overnight on say 100 c 200 f
When dry remove weight and fire till burn off
These R very stiff and can B used as kiln shelves 4 light stuff
I also use as part of my
Sceletal mould technology
Thin fire could B done just on kiln shelf
The rigidizer binds the fibres
MayB wash on top ??
Jerry if U R still with me
4 U
Fibre n Dizer tm
This is a little less complex
The above but no kiln wash
I prefer with wash but this may suit U
Try both
Dizer Boy
All the best
XXXXXXXXXXXX
Brian
							Yo Bert
Sounds good
Brian[/quote]
AUTHOR: Jim Murphy
Jim Murphy
XXXXXXXXXXXXXX
: it won't warp?
: still like you.
Fiber, Dizer n Wash
Paint with bat wash
Flat
MayB wash on top ??
4 U
Fibre n Dizer tm
Try both
Dizer Boy
All the best
XXXXXXXXXXXX
Brian
				Phil Hoppes
Bert,
Sounds cool but a couple of questions, if Spectrum sticks at 1600 will Bullseye? What about lower temps like 1500, will they stick there too or not. It sounds like a dream for float work but if BE and Spectrum stick I'll still have to kiln wash but it sounds like a cheaper solution that working with colloidal silica.
Phil
Phil
I used colloidal alumina as a seperator on Zircar RS 100 board.  I used this as a kiln shelf for a couple of years in my 20 x 40 kiln.  I painted on the alumina each time I fired. I was using BE in those days and it didn't stick when I applied the colloidal alumina. The RS 100 board I had was 1/4" thick and very hard, dense, and smooth. The alumina left a little bit of texture.  The Unifrax boards are more porous.  It seems like it will sink in more.
Colloidal silica does only come as a liquid, and freezing will kill it. The colloidal alumina can be mixed with tap water (I asked). It requires some mixing help, but not a blender, a paddle will do.You can experiment with a 20 - 30% solution (by weight). Wes told me that thicker than 30% is difficult to apply. The alumina will still work after being thawed. I am guessing that the silica is dependent on the negative ion thing and can't simply be mixed up.
				Stuart Clayman
Brian,Brian and Jenny Blanthorn wrote: .Bat Wash
Brian
I know I can be a little Batty at times, and I do like to get washed but I don't think that is what you were referring to as Bat Wash.. can you explain?
Glassworks by a Clayman
PhilPhil Hoppes wrote:Bert,
Phil
Cost is one factor. The bigger concern to me would be the ability to eliminate crystabolite from the workplace.
Our world wide research team will have to weigh in on just what works and what doesn't. Isn't Spectrum softer than BE in general? I'm guessing that there is some technique involved with the application of the material, relative to it's longevity and it's unstickability. I wouldn't take a single experience as the last word, whatever people discover.
Explain which bit ???Stuart Clayman wrote:Brian,Brian and Jenny Blanthorn wrote: .Bat Wash
Brian
Brian
				Sandy Jackson
Thanks for the info Bert. We just finished our large kiln today and were just at last step , getting ready to apply the riidizer when I ran across this info.
We are planning to order it tomarrow.
Once it is applied can we then fire directly on the HD Board/kiln floor ? Or would I need to use a kiln wash thin fire paer , etc. ?
