2 things for a newbie - safety & skutt kiln message
Just got my first kiln & started fusing - I see that Skutt sells vent hoods for their kilns. Do I need to vent the kiln when I am fusing glass, using kiln wash and no fiber paper? What makes the fumes? (I did not smell anything or see anything) Also, I have a Skutt HotStart with a Controller. As it was ramping down, it gave me the message "CPL(?) 5.52 - does anyone know what that means? It's not in the manual, and I will call skutt, but thought I would ask here first since it's the weekend. thanks.
Re: 2 things for a newbie - safety & skutt kiln message
No.
Almost anything other than what you named.
That's my license plate!
No.
Howdy there
I'm a fellow Skutt owner, and green as grass
so my 1st answer may be wrong. I don't think you'll have to worry about fumes from the kiln wash, enameling may be another story though. I've been considering buying the EnviroVent to aid in keeping the temps even, and steady. The CPL 5.52 message means the firing process was completed in 5hrs, 52mins. You'll learn alot from these guys, I have, and I've only been here for a day
-Joseph
-Joseph
Thanks & 1 more question
Thanks for the info, all! If the process was complete in 5.52 hours, then the rest of the time must have been annealing and cool down. Then the question is, once I see the CPL, can I unplug the kiln and go to bed? (I was up every half hour until 4AM and it still read 256 degrees - at which point I did finally unplug it.
Re: Thanks & 1 more question
Yes, once it reads CPL it's done so you can just unplug it and go to bed - in fact, that's the BEST thing to do to prevent you from peeking inside before its cooled.rowanberry wrote:Thanks for the info, all! If the process was complete in 5.52 hours, then the rest of the time must have been annealing and cool down. Then the question is, once I see the CPL, can I unplug the kiln and go to bed? (I was up every half hour until 4AM and it still read 256 degrees - at which point I did finally unplug it.
annealing is part of the process. when it says complete it has run through all the segments that you told it to and is cooling naturally. rosannarowanberry wrote:Thanks for the info, all! If the process was complete in 5.52 hours, then the rest of the time must have been annealing and cool down. Then the question is, once I see the CPL, can I unplug the kiln and go to bed? (I was up every half hour until 4AM and it still read 256 degrees - at which point I did finally unplug it.
