CMC vs. Kylr-Fire
				Linda Crissman
CMC vs. Kylr-Fire
Someone mentioned they used CMC with their frit.  Is there a difference in the uses of the 2?  Are there any pros or cons in using 1 over the other?  Thanks.
						Re: CMC vs. Kylr-Fire
Avery uses Klyr-Fire because it tastes better. Really! Brockelsie blu wrote:Someone mentioned they used CMC with their frit. Is there a difference in the uses of the 2? Are there any pros or cons in using 1 over the other? Thanks.
				Avery Anderson
I haven't given CMC the taste test yet (nevermind...you had to be there).
Rick LaLonde uses CMC in his frit work (http://www.richardlalonde.com). It seems very similar to Klyr Fire, with the exception that it comes in powder form so you can mix to any consistency you wish. It burns off clean as does Klyr Fire. I will begin useing it for when I need a heavier medium, but will stick with Klyr Fire for airbrushing.
Avery
Avery
My rumour level understanding is that CMC (methyl cellulose) is what is used to make klyr fire. Buying CMC is cheaper and more versatile than buying Klyr fire. I have ordered a pound of CMC. It cost $8.07 at my local pottery supplier. I haven't got it yet. I asked for a recipe, but I'm not sure I'll get that. Does anybody have a basic one?Avery Anderson wrote:I haven't given CMC the taste test yet (nevermind...you had to be there).
Avery
				Stuart Clayman
Bert,
If Klyn-fire is mae with CMC and it tastes good, do you want the receipt that makes the klyn-fire taste good.. or just the one with good taste.
Stuart
Stuart
Glassworks by a Clayman
				Linda Crissman
