http://community.webshots.com/user/jboebs
Here are some new pieces. I used all my scraps to pull stringer in my vitrigraph kiln, and made a couple of tacked fused pieces.
trying to share
Jason Boebinger
your glass fiber pieces
you don't waste any time learning to do something new. the stringer drape is interesting ... you must have a pile of hours invested in making all those pulls. thanks for show & tell. kitty.
J Campbell
Jackie Cooper
Jason Boebinger
I used an old enamiling kiln with a hole drilled into the top, turned it upsidedown and hung it from the rafters in my basement, than I fill a regular terra cotta pot with glass. The pot has a hole in the bottom that I inlarge a little and line the whole with the hole in the bottom of the kiln.Its called a virigraph kiln. Check bullseye shop notes for more info.
