Thin glass question....
Alan Cross
Post by Alan Cross »
Is it possible to get glass to go thin in the kiln....I have some bullseye rods and was wonderinf if I cut them up small will they flaten out in the kiln?
Alan :)
Alan Mark Cross
"Paint from the heart it shows"
Web site
http://www.members.shaw.ca/alan.cross/
Carla Fox
Post by Carla Fox »
At full fuse glass wants to maintain a thickness of 6mm. Chances are your rods will suck up trying to get to that thickness.
Carla
Alan Cross
Thanks Carla I kind of thought that but was hoping stilll trying to figure out how to get that thin glass without taking up blowing....
Alan :)
Alan Mark Cross
Web site
The Hobbyist
Post by The Hobbyist »
You can get thin glass by dropping it. Either throw a ring or between any other supports.
When glass drops it is stretched and thins out. With practice you can control the outcome.
Jim
Alan Cross
Thanks Jim thats a great idea......
Alan :)
Alan Mark Cross
Web site
Lynne Chappell
Post by Lynne Chappell »
I tried making shards in the kiln with very limited success. I set up wires across some kiln furniture about 2" apart. It sort of worked but the temperature is so finicky. At one temperature, nothing seems to be happening, just a few degrees higher and it drops dramatically. If you're watching, you can see it happening before your eyes. Glass droops every so slowly in a smooth arc between the wires; raise the temperature and it starts stretching from the rim of the wire and goes square in the bottom of the stretch. I didn't have enough patience to wait for many hours for it to finish, so I ended up with some too thin, some just right, and a lot of it too thick.
If you try it, use the darkest glass you have (if its transparents you're after).
rodney
Re: Thin glass question....
Post by rodney »
Alan wrote:Is it possible to get glass to go thin in the kiln....I have some bullseye rods and was wonderinf if I cut them up small will they flaten out in the kiln?
Alan :)
what if you got the rods, laid them in the kiln and put another kiln shelf on top of them, making a glass rod sandwich,,,,seems like the glass would get soft and the weight of the shelf would flatten them, , and then a quick flash of the kiln would freeze them in that state,,,,would this work
Alan Cross
this might be worth a try.....even with thick glass but it might not melt under the shelv...\
Alan :)
Alan Mark Cross
Web site
