Overfire Black Magic?
Does Black Magic react with glass if over fired (1450F x 10min). I've got a bunch of gray/black glass in my kiln that wasn't that color when I put it in.
- Paul
- Paul
Doesn't there need to be something in the kiln to make it a reducing atmosphere? Also, it seems that only certain colors turned dark (black).Ron Coleman wrote:Black Magic (Back Magic) has a high lead content and wil turn dark in a reducing atmosphere in the lkiln. I don't know if the process is reversible if you fire again with the vents open.
Ron
Curious if anyone else has seen this -- and if it ever happens at lower (1000F) temps.
It's probably a reaction between the glass and the Back Magic. The lead in the Back Magic reacts with glasses that have carbon in them. I am relying on memory, so carbon might not be it....such as BE's French Vanilla. It's the same reaction you might see with a turquoise glass (reactive element is copper) next to a yellow glass (cad / sel). Brown to black discoloration...in your case splotches.
This is what I learned in a glass fusing class, but since it is ancient history...I may have inadverantly revised it
...Don't take my word, do the research to see if I have it right...If I remember correctly, these are the reactive elements and they don't play well with others. Lead reacts with carbon and CSS (cadmium /selinium?), copper reacts with CSS (cad/sel?) and carbon.
What glasses are these? I'd have to look at my chart to see.
Sray A will do the same because it contains lead, which is why I use either SuperSpray or Borax.
You might be able to blast or grind it off, but don't really know how deep the stain will penetrate.
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
LaniLani McGregor wrote:I agree with Cynthia (mostly)
Lead (and Back Magic has lots) will react with sulfur to make lead sulfide (black/brown). Many amber colored glasses contain sulfur (called ?carbon/sulfur ambers?).
Lead will also react with selenium to make lead selenide (black/brown). Many red and orange glasses contain selenium (Cadmium / Sulfur / Seleniums or CdSSe)
If the Back Magic is turning something other than an amber, red or orange glass dark, I'd be interested to know what the glass is.
L
Gee did you ever imagine that you would become a leading expert in glass chemical reactions
![Question :?:](./images/smilies/icon_question.gif)
My grades in HS chemistry were C,B,A,A,A,D
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
