I moved. Ive lost my firing log.  My life may be over.
anyways, now I need a recipe for plater water for 1500 deg casting.  I need a volume one not weight.  Does anyone have one?  thanks if you can help.
Liam
							plaster water ratio
plaster water ratio
W.W.S.D.
(what would spab do)
Re: plaster water ratio
As much plaster mix as you can get in the water and still manage to get a pour with some resolution. The less plaster to water, the easier it is to pour and the weaker the mold. More plaster, stronger mold.Liam wrote:I moved. Ive lost my firing log. My life may be over.
Liam
				charlie holden
