Hi fire technique
Hi fire technique
Can someone be so kind to give me some directions to learn about this Hi fire technique? I´ve never heard of it. Any link? Any book?
Luiza
Luiza
Brian and Jenny Blanthorn
Re: Hi fire technique
One thing U gotta watch out 4 if lots glass is the glass pushing the sides outLuiza wrote:Can someone be so kind to give me some directions to learn about this Hi fire technique? I´ve never heard of it. Any link? Any book?
Luiza
I wedge 2 the sides of the kiln
But I always got a bit of fibre 4 expansion
Clifford Ross
Amy Schleif-Mohr
Amy on Salt Spring
Speaking of sandblasters--how much does a sandblaster setup cost--nothing fancy, just one capable of getting kiln wash off the back of things or maybe creating a matte finish? I know there are probably a lot of variables as far as cost is concered, but are we talking like $200 range or $800 range or $1500 range?
-Amy
-Amy
Amy Schleif-Mohr
LuizaLuiza wrote:Thanks Charlie
As I use float, I imagine that I must use 1700 .
I cant´t wait to try. Need more kilns, so many new options...![]()
Be aware that float glass does not have the flow properties that Bulleseye glass has. It needs at least 80 degrees more heat to soften than Bullseye and even then will not behave the same.
Hi Amy,Amy on Salt Spring wrote:Speaking of sandblasters--how much does a sandblaster setup cost--nothing fancy, just one capable of getting kiln wash off the back of things or maybe creating a matte finish? I know there are probably a lot of variables as far as cost is concered, but are we talking like $200 range or $800 range or $1500 range?
-Amy
I got my sandblaster setup from House of Tools and Princess Auto. I imagine one of these stores is in Victoria (for sure in Vancouver).Compressor, cabinet (siphon feed), hoses, water trap came to under $1000Can. Works just fine. I can always add a pressure pot later if I need it .
Cheers
Amy on Salt Spring
Thanks for the Canadian pricing. I'll look and see if either of those places are in Victoria (an enormously easier trip for us than going to Vancouver). Hmmm... compresser and hoses I recognize, "siphon feed", "water trap" and "pressure pot" are new terms for me. I'll go take a look at the archives.Bob wrote:
Hi Amy,
Cheers
-Amy
Hi Amy,Amy on Salt Spring wrote:Thanks for the Canadian pricing. I'll look and see if either of those places are in Victoria (an enormously easier trip for us than going to Vancouver). Hmmm... compresser and hoses I recognize, "siphon feed", "water trap" and "pressure pot" are new terms for me. I'll go take a look at the archives.Bob wrote:
Hi Amy,
Cheers
-Amy
Water trap is a small device that allows water in the pressurized air to condense before it gets into your cabinet (and possibly make the abrasive damp). I put mine on the side of the cabinet ... immediately before air goes into the cabinet. Siphon feed is the cheapest type of system. The "gun" has an air hose in the handle, and a short hose attached to the barrel of the gun. The end of the hose is buried in the abrasive. When pressurized air passes thropugh the gun it draws abrasive up the tube .
Pressure pots are a separate barrel shaped container that mixes abrasive with the pressurized air before if enters the blast cabinet. It is more efficient than a siphon system.
There that is all I know about sand blasters. The GlassStar web site has a great introduction to the components of a system.
Cheers
those blasted guns!
Are there any alternatives to the pistol-grip guns that you have to squeeze the trigger? Those just make my hands ACHE after about 30 seconds. I spent several hours sand-blasting yesterday and I swear, I'm about to file for disability!!
Re: those blasted guns!
footswitchCheryl wrote:Are there any alternatives to the pistol-grip guns that you have to squeeze the trigger? Those just make my hands ACHE after about 30 seconds. I spent several hours sand-blasting yesterday and I swear, I'm about to file for disability!!
i have one on my grinder, and it's saved having to replace the switch a couple times over.
